- Mar 20, 2008
- Fairbanks, AK
- Manual
Well it's been over a year since my last post and boy have I worked on my Lil Hoss/I] as he is now affectionately named. I wound up not getting the old car alarm pulled and it's still in there taking up space but here is a list of things I have done since.
Last winter we had a week or so spell of -60 degrees and my radiator fluid froze solid. Needless to say I had it good for about -50 but with that cold sap EVERYTHING was freezing. Heck, it wouldnt even start even after being plugged in all night, I had to light some charcoal and let it cook then set it under the block to warm it up enough to turn over. So, with it being so cold I got away with cutting the water pump belt and running it the 12 or so miles to the hobby shop. Got a new pump from NAPA and after letting him sit overnight to thaw the fluid I drained it and replaced the water pump and hoses. Made it through the rest of winter.
Summer time 09... I had by now saved up enough money to get the 3" suspension lift from James Duff. Now I am learning as I am going. Everything I know about my Lil Hoss is from getting in my Chilton's, getting in the hobby shop on base and getting dirty. It's a pain in the a** but I can do it all blindfolded almost now! I had some leave to take and decided to put the kit on during that week. I am glad I had a week!! What a job!! Rivets are the devil! Drilling, sweat, blood, DIRT, Cursing,
Rust, Sparks
, Cursing, DIRT, grease...frustration,
put on, take off, drilling, measuring, DIRT....happiness...Cursing! Lots of pics of that one. Soooo, 3in lift on and talk about FLEX.
Well as you all may know but I found out the hard way when you put that kind of lift on your steering gets a little whacky. I had been pricing new rims and tires on Tire Rack and found the ones I wanted but decided with the first snows now hitting (it's October by now) that I needed an allignment first and foremost. Talked to my trusty gear head friends and decided to run down to a local shop and have it done. Ok. Took it there and they called me back later that day and told me the bearings and seals and ball joints needed replaced before they would even touch it. They could do it but it would cost me. I said no thanks and decided another learning opportunity was on the horizon. They wound up charging me $65 bucks for the look and putting a new castle nut on my tie rod... REALLY?!
I rebuilt the enitre front end. Bearings, seals, dropped the diff and cleaned it out (this involved dropping the pass side traction beam from the new drop bracket because the diff wouldnt clear it..pissed me off..the fluid looked like chocolate milk... not good), took me a day and a half but at the end...I was very pleased.
So not wanting to go back to the rip off joint I decided to go to Midas. Reputable right?Midas called me with a quote of over a grand. Told me I needed to replace the pass side ball joints and install a new camber adjuster bolt and then do the allignment. I said no thanks and went to get my feelin no love Lil Hoss. Luckily MIDAS decided not to charge me for the "look" and instead gave me a the inspection sheets and the costs sheet. $25.96 for "shop supplies"?! Really? Ill do it myself thanks.
When I got into my Chiltons bible I realized that I would have to tear apart the pass side front end again to replace the ball joints. I had quite alot of choice words to say as I read this but decided to get a third opinion. I went to my friends at the hobby shop and talked to Rick, own his own shop, runs the hobby shop on base,... He is my Obi Wan Kanobi. Rick helped me check the ball joints and said I didnt need to replace them. The pass side was so minimal that it was just fine as it was. The drivers side had no tire wiggle at all. Yay for me! He then helped me adjust my tires and I learned the meaning of "toe-in" and "toe-out". Apparently my tires had been fighting each other and that was the major steering problem. I adjusted to his instructions and an hour later left the shop with greatly improved steering.
After reading online... ALOT... and talking with my gear head friends... ALOT... I decided to go to Tire Rack and look at tires and rims. I wanted the biggest tires I could fit at a decent price and some decent rims (nothing flashy as I plan on getting them REALLY DIRTY). I found what I wanted and printed off the sheets..even had pictures! I had heard of a place in Fairbanks from another friend and decided to go there to see if they could match the price. American Tire and Auto. These guys are great!! I worked with Anthony and after some checking he told me he could match the price and do the allignment. The tires I wanted retail up ehre for $265 a piece. I got them for the Tire Rack price of $160. Rims? About a hundred a piece.
Today (4 November). I just got back from AT&A. 33X10.5R15 BFG Mud-Terrain T/A KM2 and 15" Ultra Wheel rims. Computer allignment for $65 and Lil Hoss is running and looking amazing!
Next up? Gotta get beter gears in the rear cause I DEFF notice the difference (thinking 8.8 explorer?) and also thinking about selectable lockers. Any ideas?!
Rust, SparksWell as you all may know but I found out the hard way when you put that kind of lift on your steering gets a little whacky. I had been pricing new rims and tires on Tire Rack and found the ones I wanted but decided with the first snows now hitting (it's October by now) that I needed an allignment first and foremost. Talked to my trusty gear head friends and decided to run down to a local shop and have it done. Ok. Took it there and they called me back later that day and told me the bearings and seals and ball joints needed replaced before they would even touch it. They could do it but it would cost me. I said no thanks and decided another learning opportunity was on the horizon. They wound up charging me $65 bucks for the look and putting a new castle nut on my tie rod... REALLY?!
