Junk yard ranger going bigger
Holy lift blocks batman
gotta love cut and extend jeep arm!
they work and this is the 5th set I have built and have never broke one .....
What defines a block? a separate chunk of steel between the spring and axle
What defines a perch? a solid platform connected to the the axle that the spring rests on.
yes they are tall, they are 10 inches tall to be exact, but are solid and tested it is a budget build and mud toy I could not give a crap if I roll the damn thing. Just give me a reason to build bigger and badder :D:D:D:D
Just my .02 cents on the blocks/perches......
if he was running some nasty built big block or even a small block with nitrous then i could believe the blocks MIGHT be a problem but a 4.0 isnt gonna make THAT MUCH power or torque to create massive axle wrap
that thing is huge! Nice build.
Thanks .... Wait till u see the tires I am gonna be running ... and yes ur right the OHV 4.0 is 160 hp stock and 225 torque , between the chip, cam, head work and exhaust I might be at 200 and 245 MIGHT so axle wrap, yea I had some, but since the ladder bars and the rear spring are stiffer then a retards pecker at a whore house :shok::shok::shok::shok::shok:
That is one scary lookin rig..i hope you wear a helmet when you drive that thing around
I know you got the axles from someone else but how are the brakes setup? Disk wheel brakes! I need pics of this:icon_thumby:
I jusy wanna see it with tires on it...and unless your tryin to take turns at high speed *which mud boggers generally go STRAIGHT* I dont see where its gonna be any more un stable than a heep cj5 with 35s on it
do you even need those huge lift blocks the tires look like they will fit on the side of the body you can lower it a little and have the tires stick out right next to the wheel wells
The rims are on backwards and I don't think those are what he is going to run either.
Geeze....guys you need to leave him alone with how big he made it...it's his anyway.
im not making fun of it i like it cause its differnt i just think it would look better a couple inches lower
it would probably look pretty sick slammed too you should ask hazmat to slam it for you just to for fun lol
