jsnyder 2.0carb.out 2.3 efi-in
jsnyder
hello, i need info. on the easiest way to switch from carb. to e.f.i. ?1988 2.0 to 1989 2.3. have running donor truck. also want to put dana 20 tcase.in.have the three spd. 77bronco tranny still together. also have 81 lincoln aod and 1974 c4. question which one to use? I want to use the aod i'm not going to be off road much and will just putz around when i a'm. have the 77 bronco axles too.
none of those transmission will bolt to a 2.3, use ur stock tranny and t-case, unless u feel like havin alot of custom fab work and one off project
my stock tranny is toyokgo wussy. and no removable tailshaft. fab. is not a problem, what will bolt up is. and still be able to shift.
