Josh40601's Build Thread. (D-ranged)
only takes about 10 minutes to swap out both hubs.
edit:
Since Kyle is a biotch :thefinger: and called me out for being slow, I timed myself. less than 9 minutes using a T handle allen wrench
Good thing I don't pay you by the hour.......
Could do both in less than that
:thefinger:
:thefinger:
You know, those are the exact same words I told keith about getting the truck done.
thanks brother!
Update:
Well, I went out to the shop last night, the track rod is NOT in the truck. It is bent and ready to be installed, but isn't. There was no change to it since last week. At this rate, really worried about getting it done by Halloween. We did get the battery relocated to inside the cab (took the rumble seat's place). Truck should be started and running tomorrow. Going out to work on it Wednesday, Thursday, and all day Sunday. Hopefully we will get some good ground covered then...
thanks brother.
edit:
LOL....
:thefinger:
thought you might like that
Looks bitchin man. I've got the same axle going under my 94. I want coilovers :drool: :bawling:
they sell them everyday! just save up and buy some!
got a good amount of work done last night.
All the wiring is done, just need to mount the fuse box and battery.
Track rod is all tacked in and good to go. We have to notch the crossmember because it will be limiting travel.
Front wheel spacers are on.
Getting closer! Here are a couple pics.
One at ride height
and
one at full droop
coil overs make things just looks smaller :P love it man!
So if coilovers make things look small, you can only imagine what this thing like like in person :)
Have all the front end components except head lights, which will be here next week. Everything is red so I need to paint it, but everything is oem ford parts :)
