Jet ski towing
steveoelo
Mighty Canuck
Was wondering how other rangers pulled a single jetski? Have a 2wd 2.9 and I feel like it would pull the ski down the road just fine but how would it react pulling it out of the water?
Should be just fine with some weight in the bed and reasonable tires.
Full size trucks slip on wet ramps.
It is simply a matter of traction with something as light as a jet ski, not power
I figured that, got the stock 14s but the tires have really good tred. I have sandbags, would you think that would be adequate weight? I'm guessing the ski weighs maybe 800 with the trailer
Yes, should be fine.
You can have one sand bag tied so you can open it and put a cup inside it.
Then if needed throw some sand down for better traction.
Also rubber mats are helpful for traction.
No one that has spent anytime on boat ramps has not running into slippery situations.
I ran into a spot where some one had poured out a bottle of dish soap on one side of the ramp, playing a joke on his buddy.
Well I was the next guy that used it, yea real funny................., actually it was funny, but at the time.............
2WD trucks are usually OPEN differentials, this means the easiest tire to turn gets 100% of the power, so if a wheel starts to slip ALL the power goes to that slipping wheel, lol, yes not very good but that IS the way it works.
An old trick when an OPEN differential tire starts to slip is to hold out E-brake release and push down on E-brake pedal, this will slow down the slipping wheel and transfer some power to the other wheel, once you get moving let off brakes
Not easy to do this with a manual trans and foot E-brake, but with an Automatic trans and/or a Hand brake it is easy peasy
Right man, she's an open differential with a 5 speed. Should make quite an experience for the ramps where I go are terrible concrete. Thanks for the advice
Seen Rangers put in regular boats no problem, so I don't think you'll have a problem with the jetski. Low gear, take it easy on the take off. Don't floor it. Did a jetski a time or two with my old 84 that was 2.8L, 2wd, and manual.
