Jeep dana 30 i want the best
definatly another situation for keep the ttb:icon_cheers:
i dont play that much i never crawl. i just play in mud or snow. and i dont even do that much. just one in a while. so i with me just doing this would a dana 30 hold up or im not really sure on thsi SAS stuff
So you think a straight axle looks better? Is that your reason?
The TTB is the same thing as a straight axle. All the same parts. The only difference is that one axle shaft has an extra u-joint in it, and the axle housing is seperated with the end of each half hung from the opposing frame rail. That's it. The D35 is not weaker than the D30--it's stronger. There is less unsprung weight in a TTB making it ride more smoothly as there is less energy for the shocks to have to control. The downside is that if you don't know what you are doing when you modify your suspension you will hit some geometric limits that can make the truck dangerous and unpleasant to drive. This makes people who lifted it, had trouble, cursed it and tore it out say bad things about it. All of these issues can be corrected though. You can make a lifted truck drive like a stock truck if you understand how to set it up. Lots of people here can help.
My truck's suspension is as floppy as a wet lasagna noodle and it does not dip, dodge, dive, duck or dodge when driven. It will take you more thinking to do the D30 swap than it will to level your steering arms.
Unless you think the D30 is more attractive. Just make sure you list your D35 on here instead of scrapping it.
the 5 "D"s of Dodge ball ..........
4.10 axles can be found in 4 banger Cherokees and some 5 speed 6 bangers.
And all 4 cyl wrangler's, you might be hard pressed to find the 4.10 in a 6 cyl wrangler unless it has been changed out.
i have a 94 ranger and i want to SAS it i hate the independent suspension! but i am curious which year jeep D30 axle i should go with i don't want the disconnect shit i just want a reg axle with locking hubs!
Also u mentioned a Scout D44 how much wider are they then a ranger 8.8 axle and whats the bolt pattern on them? any help would be most appreciated!
The disconnect ones ,as I have read, have a casted control arm mount and the non disconnect ones dont and some guys say the cast arm mount is better to have. All they do is get a none disconect axle shaft, replace it with the disconnect one, and put a metal cover where the disconnect assembly was.
They have the same bolt pattern as the ranger rims.
Also look in the Tech Library and you should be able to find a write up of the types of D-30's and it will help you look for the one you need/want.
oh and i want to leaf spring it, the coil suspension isn't for me! i want it to be as close if not the same width as a rbv axle, without the disconnect BS! And what years i should look for!
good luck. on the D30 with locking hubs unless you buy narrow track old jeep or pre 67 bronco. if you wish to match the 5 x 4.5 5 bolt lug pattern
Your best bet if you wish to run leafs (downgrade) would be to run a Wagoneer Dana 44, the only problem is it is 6 bolt. You could run a rear Toyota 8" to match bolt pattern or the rear wagoneer Dana 44
Alright well does anyone know anything about the D30 CJ axles? i know they're leaf sprung and i checked on the Warn website and they make locking hubs! so is there a reason no one uses them? Whats the weak link on them? i appreciate all the advice out there!
Passenger drop wont work with your stock drivetrain setup.
Alright well what Straight axle can i use that is leaf sprung and is really similar in width or the 8.8 ranger axle, that i can use manual locking hubs on?
