jeep coils
cencal4x
los banos and morgan hill, ca
hey, i looked around for a bit but could not find all the answers i need. will jeep cherokee coils fit in the spring buckets on my 93 4x4? and if so, here is my possible plan, i want to level my truck, i got bout a 2-3 inch rake i want gone and found some 2 and 3 inch lift coils for a jeep, could i use thses on my truck with no problems and would i get the same lift as advertised on the jeep? and other than needing to realign my steering, do i have to worry about any bad camber changes, or will that little lift not do anythin, thanks
You need at least 3" or so lift to make good use of Cherokee coils. 2" is the max amount of lift you can go without also changing your axle brackets (installing a full suspension lift).
If you just want to level it out, I would look at using either a set of leveling coils, or some coil spacers under your stock coils (or washers placed under the lower spring seats). Realignment of the camber and caster will be required.
Steering should be fine as it is with it leveled 2".
