James Duff Heimed radius arm mounting
Dugan
New Castle, DE
I was going to mount mine with the arm running across the top to give me more ground clearance, but it seems that when I look these arms up they are mounted with the arm running across the bottom.
Anyone have issues mounting them... upside down on the opposite side?
You can't mount them upside down the caster will be all wrong and I doubt it will even bolt up.
X2, it will bolt up, but your caster will be so far out you won't get it aligned....
SVT
SVT
Ok, this truck will never be on the road again either but ill mess with it. I guess them being mounted lower will help save my front driveshaft
