James Duff 3 Inch Stage 1 Lift
RangerBoy94
Northern California
Just scored a JD lift for 200 with brand new shocks. I was curious of what you guys think of this lift. How does it perform off road? Stregenth? Overall Quality? I know radius arm drop brackets suck but I do plan on fabbing a tranny cross member and extended radius arms.:icon_thumby:
JD is good stuff for sure. It should serve you well. Get a drop pitman arm for it though if you didn't get one, it'll go a long ways in bettering your handling, as well as wear on your front tires.
Ya I'm getting a drop pitman arm I was thinking of getting a extreme drop cause I was planning on putting some coil spacers on after the lift to fit 33's a little more comfortably.
The Duff lift is a good choice!! :icon_thumby:
Duff does have some good stuff, I ended up going with cage to do my sas.
