well i took my dash apart to inspect the wiring and to relocate my tack.
turns out, i found alot more problems than i thought i would...
wires disconnected all over the place, wires cut, plugs unplugged, etc...
not too suprising, since the previous owner is a mechanical/technical idiot.
well i fixed most of the wiring and i relocated the tack. but i found one thing that i want to fix... and i want to know what it does and its importance.
when they wired the tack they unplugged an input that is located behind the top right hand corner of the glovebox. and cut one of the wires and connected the power wire from the tack to it. but they never re connected the cut wire, or even connected the plug back into the sensor.
what is the sensor for? is it important? i want to reconnect the wire and plug it back in and wire the tack CORRECTLY, so it works when i turn on my lights...
i also found multiple cut wired all around. i will get pics soon... ive looked around for the info but no luck.
thanks guys
kolton
thanks guys
