PanamaExpat
- May 28, 2011
Well the big day finally has arrived. After I can't remember how many months of tying up all three garage spaces with the B4000 I finally get to set the cab back on the chassis. So since I am sure y'all are tired of hearing me whining about it here it is.
First I had to get the necessary tools ready. Lots of them.
Next we had to get the cab in the air.
Then we had to locate the chassis in the yard.
^^ NOTE: More necessary tools
Rolling in the chassis.
Getting closer.
Getting lined up.
Setting down:
^^ Didn't figure out we had the cab mounts from the rear in the front position until we went to put in the front bolts and had about 2" of space between the core support and frame. Took just a minute to lift the cab a few inches and get the mounts in the right holes.
Shop supervisor inspecting the under side alignment.
Ready to bolt down.
All good time for more beer.
Had to bump things around a bit to get the cab to chassis alignment just right but all in all it wasn't too difficult. I do recommend however if you do this to have at least one helper to hold things in alignment while you operate the hoist. I have decided that if anything major needs done on one of these trucks it is easier to remove the cab and bed then work on the engine, transmission or what have you. Well tomorrow is another day and I can start getting everything connected. Hopefully will test start it and maybe take a spin around the yard Saturday or Sunday... But I just remembered this is Holy week and nothing is open so if I need anything I can forget it until Monday.
Thanks for reading through this long post. I hope that someone finds it useful.
Time to celebrate....
Getting closer.
Getting lined up.
Setting down:
Ready to bolt down.
