97ranger22bronco
- Apr 7, 2024
- Dallas, TX
- 2.3 (4 Cylinder)
- Manual
The tow truck dropped the Ranger off earlier today. Getting it in the garage was...interesting with four absolute flats lol
I made a list of items to get done to bring it back to life. Would love some feedback on any items that are missing and/or that are not needed.
- Change oil/filter
- Flush coolant in radiator
- Flush heater core
- Flush brake system
- Change transmission fluid
- Change transmission filter
- Changer power steering fluid
- Change differential fluid
- Change transmission pan for one with drain plug (if not there)
- Replace radiator hoses
- Replace fuel hoses
- Replace water pump and gasket
- Replace oil pan gasket
- Replace spark plugs and wires
- Replace ignition coil
- Check/replace alternator
- Check/replace distributor
- Change air filter
- New battery
- Replace battery cables
- Change battery tray
- Clean fuel tank
- Replace fuel filler elbow
- Change belts
- Change thermostat
- Replace fuel filter
- Replace fuel pump
- Check inner and outer tie rod ends
- Check brakes
- Check leaf springs
