issues with inserting images
Seems to work ok on this end.
If you're having a problem, what is the TRS Style (color theme) you're using (bottom left of page).
white with black. the problem seems to be on certain posts/threads. here it is working normally.
if I now go back to the other thread it won't work.
Edit: I just noticed that the problem posts do not have the attach files box at the lower left. they do have insert quotes but who 'da hell want's to hear what I'm saying??
oh, that's my improvised vice for holding a lower control arm.
the scrape marks under the arm show how much it moved, the marks to the right are hammer scars.
@Jim Oaks I'm also having an issue. I get the loading bar after attaching the image but it never moves off of 0%. Don't know why. Tried different images and still same issue. I've waited up to 30 minutes and still 0%. Uploading from android btw
phone doesn't have perms to access photos with this program?
just guessing
or maybe cookies not permitted? again wild guess
if it works for other people then it would have to be an issue in the specific device vs the forum...
Samsung s10e android phone. Can upload but never know if it did. And no way to embed into the thread, just a thumbnail. It's been an ongoing problem ever since this new forum host. Over 2 years...
wow. I have an Android phone maybe I will try it. I never use phone to post as of yet. it doesn't have the 'full image' button to put the big pic in the post? because that would be weird.
remember I'm just a user I don't know anything about admin on this particular forum. I have a forum and .com site but it's different software.
they (forums) are usually weak on video and sound uploading but for pics there should be no problems. the site has to allow the type and size and that user is allowed to upload, etc, but the admins here would know all about that and I suspect the settings are correct or everyone would be having issues.
Mobiles and regular computer screens often have different settings sometimes it is an add-on to the site. what I'm saying is the forum can see what kind of device you are on and you will notice that often web sites look quite different on a full screen vs on a mobile small screen. I'm just noting that, because, if you have a regular computer, and it works fine, but doesn't work on mobile, that would tell you something. and if there are other Android users that have the same problem that would be useful info for sure.
I've been using my phone almost exclusively since about 6 years ago. Only had a problem since new forum software.
@Jim Oaks
I have no trouble with my Android phone attaching the picture
I have to say it acts a little weird, if I make it full size then go to put in text it makes the pic small again but you can put in text then make it full again
my phone is Moto G Pure, Android v. 12
so if yours doesn't work even though I understand you are saying something is different about the way it acts after the software change, it's apparently not a systemic phone or Android issue
if I were you I'd try going to other forums (maybe you already have) and see if you have similar issue or not
then if no issues for you in other forums but issue only here we are left with unknown problem specific to your phone or its setup, regardless how it happened
you should have the button "Full size" on your screen when you have uploaded pic...
is it possible you would want to clear the cache, maybe phone is retaining old vs of something
but after 2 years... I dunno
if your phone is like mine you get other buttons to do stuff but you need to just use the buttons on the site itself you probably know that to me it's confusing I hardly ever use phone except for texts.
can't think of anything else except maybe post pic even if t-nail if that's all you can do, what's showing on your phone when you are posting - you should see your Attach buttons etc.
to add... if changing the display style or color makes the screen look otherwise different, I'd say that's a forum software issue because that shouldn't happen
the two things are not logically related
meaning let's say the "Attach" is blue and you change to screen blue, obviously the software has to change the button to a different color
but I doubt it's that straightforward, it would have been caught in testing and QC just about for sure
if it is in fact a bug they will/should fix it they being the software providers but admins would have to confirm/submit on that
When I have more time I will take screenshots and try to upload them. But it's really frustrating because I don't know if they loaded until I go back to the main forum threads and then find this thread again.
I'm having a hard time visualizing it; seems like you attach a file, then you see it small with buttons to insert if full size, or t-nail, or delete it. I don't get why it sounds like your screen doesn't update once it's attached.
it seems like you see something different than I do and that "shouldn't happen"
I posted a pic to another forum. Here it is exact, but the pic format is different and won't show here;
Chicken, 7 bean soup mix, onion, carrots, potatoes. Simmered for 5 hours. Yummy!
![20230314_175314|412x550](upload://gtrWDwDZAR21mnTskLgiQAlXbN3.jpeg)
Changed forum colors.
Nothing changed, I still don't know if the pic has uploaded until I go back and forth a couple times.
