BlueKitsune
- Dec 14, 2013
- Automatic
I'm hoping I can salvage this trans as I don't really feel like dumping $1500 on a reman one but lets see what you guys think.
5R55E the previous owner said he had a friend replaced the transmission that came from a newer explorer. So I'm not 100% sure its a 55E but the valve body looks right.
Anyways, Drive is extremely slow to engage, taking between 4 seconds up to a full minute. Tho now it never engages. And on start up you can hear what sounds like a hydraulic whine coming from the transmission for a minute or two.
Reverse still works perfectly
When I was able to get into drive I only seemed to have 1st 2nd and 3rd gears. Turning O/D on or off never made a change and after a short drive the O/D light would start to blink.
Fluid has gone from clean and new to burnt in a little over a month. level never went down.
I just pulled the pan off the transmission and removed the valve body, no blown gaskets and it looks like the TSB was already taken care of. but it seems like its full of sludge?
Thats where I'm at right now. Think I might be able to clean up the valve body and do a full trans flush or is it just toast.
