Is this the correct fuel pressure damper? xl5e-9f775-ab
2003 donkey
2003 mazda b300
2003 mazda b3000 3.0 flex fuel vin v
Thanks for the help!
Think you ought to go back to the other post and go thru all those suggestions first. Unplug the vacuum hose and see how it runs.
Dave
I did a compression/balanced test good! new plugs wires injectors/pulse is good pvc hose is good. Valve stems are leavel no broken springs.
2003 mazda b3000 flex fuel vin v
Is this the correct fuel pressure damper xl5e-9f775-ab ?
Thanks for all the help!
