Is this oil pan or main seal?
OdinAF
Earth
As the title says. I already tried running AT-205 with little success.
Off hand I'd say it's oil pan and timing cover. Notice how it is all over EVERYTHING, but in the last pic you can see clean metal behind the balancer? If the front crank seal was leaking it should be slinging oil up onto the timing cover in the middle.
Also, it looks like there might be some leakage of the coolant galley where it goes through the front cover.
You are leaking coolant from somewhere. That's what the green fluid is.
Sent from my SPH-L900 using Tapatalk 2
Thats it. I'm pulling the motor and over hauling the whole thing.
Why do it half way...........sell it and buy new
Main seal leak will pump out oil, no wondering about it, you have a gravity leak not a pressure leak.
I would pressure wash the under side and then keep checking for the ooze.
