is there a stronger tranny to replace a M50d-R1
94 lngbd
Lakewood,Wa
I have a 94 Ranger 2wd that see's 2500-4000 lbs of loads several times per month. Is there any other tranny from a 2.3L that will work for my truck? Im wondering if the SVO stang or Turbo Coupe T-Bird trannys are any stronger, or if they would even work in the same mounting positions as on my Ranger.
I don't think anybody ever intended the 2.3 to haul that much weight.
For towing an auto is actually stronger because the gears are in constant mesh and have a larger contact surface. An A4LD properly built and cooled will be stronger.
Your transmission is no weaker than the units put behind other engines in the RBV lineup. I wouldn't use an A4LD unless I had no other choice. Bad personal experience.
What would take a little load off the clutch and transmission is a lower axle ratio. I'd do 4.10's in a heartbeat when towing in your situation.
already have a 8.8 in the truck with 4.10LS
gears. Running Lt 235/75/15s. Well picked up another tranny in great shape for $80. Of course I had to remove it ,but even removed the top cover to inspect all the gears & they are all in great shape.
