2.3L ('02-'11) is there a fuel return line?
cozz
15+ Year Member
want to flush my fuel injectors, and can't figure out if there is a fuel return line. I see the pressure regulator, but only the one fuel supply line. Truck is an 01 2.3L...Any help would be appreciated
I think by 2001 return lines were gone
it would appear so from what I can see, but I'd like to know how the pressure relief valve works then, lol...I can see a vacuum pot on the rail- how the heck does that work? where does it relieve the pressure to?
so for future reference, there is indeed no return line- 2 cans of thru rail cleaner in my vevor fuel injection cleaning machine at 60 psi worked great. The Schrader valve is in a horrible location, so it's best to just disconnect the fuel line and hook up from there. Expect some valve clatter which will scare the hell out of you...
@cozz valve clatter from injector cleaning???
can you 'splain that a bit?
I know the 2.3 Duratec has mechanical cams but valve noise from injector cleaning is new to me.
It's gotta be pinging cause of the cleaner. Right?
You ever get the pinging corrected??
