markalmand
Thank you sgtsandman, Just saw your reply, really appreciate quick response, this only makes since, I will continue with vacuum throught hose in flll spout till no more comes out. Tnanks again!
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
So it is a good idea to get as much of the old trans. fluid out that you can before refilling with fresh Dexlll/Mercon after filter change?
No break in period and you only need friction modifier if you have limited slip. I use Motorcraft as a first choice and the nasty smelling Ford Performance stuff in the Auburn Pro in my Mustang and the Aggressive Yukon unit in my truck. I stinks awful and isn't environmentally friendly but it works great.After I change my rear axle fluid in "94" Ranger automatic is there a break in period on the new Lucas 80- 90 gear oil, or can I start pulling my trailer right away? Asking for a friend,,, And is friction modifier needed, and what brand?
They stay out of it too often. I wasn't certain the differences and running out of time got the only two they had there, at $10 each.How can you not find it? Walmart and every parts store sells Mercon rated ATF.
Why would you need to ask the Walmart employees anything? Go get it off of the shelf and checkout.They stay out of it too often. I wasn't certain the differences and running out of time got the only two they had there, at $10 each.
Put them in and all too soon learned it was one I certainly did Not want, for the damage it would do.
There's also one other thing about WM, don't expect any answers from their employees to be accurate
Yesterday I stopped at a store I rarely visit and got exactly what I needed, at half the price![]()
at times I get the notion they might actually have some clue as to when they might get something on the shelfWhy would you need to ask the Walmart employees anything? Go get it off of the shelf and checkout.
