David S
Hi everyone, I have a 2002 Ford Ranger XLT 3.0 and the heater won't blow warm. I flushed everything out and it worked for about 3 days and started blowing cold again.
I took the hoses off the heater core and flushed it out until clear water was flowing through. It took several minutes before it did. Someone else mentioned the blend flap also.have a thermometer? check both hoses.
the amount of temperature difference will point to what's happening.
when you flushed it did you also reverse the heater hoses?
EDIT:
it can be a bit messy, for testing you can remove the heater hoses and attach a garden hose to check flow without the engine running.
I'd still check the blend flap first.
didn't reverse the heater hosesI took the hoses off the heater core and flushed it out until clear water was flowing through. It took several minutes before it did. Someone else mentioned the blend flap also.
