intermittent turn signal operation
rangerwarne10
The Great Northwest
i know what you're thinking, turn signals are supposed to flash intermittently, but mine are working fine, then not working at all, either side. Any thoughts?
What about your hazards?
I'm going thru the same thing... signals work sometimes, sometimes not... hazards always.
check the connector on the switch mine was loose I am guessing from the incident when the front bumper pretzled. vibration will shake it loose too if it wasnt locked in properly.
Well, go figure... I fiddled with the Flasher Relay (in the fuse box area - big silver round thing) and what do you know? It seems to work fine now! When I say fiddle... it felt loose when I grabbed it. I pulled it out (it has two prongs) and pushed it back in. All is well for now. If it works its way loose again, I may bend a prong or throw some tape over it or something. Maybe pick up a new one... looks pretty cheap.
Good luck if you have the same problem.
