DangerRanger37
- Nov 6, 2016
- Automatic
Hello,
Just pulled upper and lower intakes. Did the gaskets. Checked for vac leaks and found none. (1997 4.0)
Typically I'll throw just a P0171 and not P0174 but the two have been coming on together lately. I have been using torque pro to attempt to monitor whats going on. I have cleaned the MAF and it's readings are inline.
Now when I go to look at the fuel trims the all (short and long term banks 1 and 2 come up) -100%. My O2 sensor voltages come up as 0.0V.
Huge help huh. So looking at the mode 6 test results this is what I see:
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$01 CID:$11
- Rich to Lean sensor threshold voltage(constant)
Min: 512
Test result value: 1,024
PASS
TID:$01 CID:$21
Min: 512
PASS
TID:$03 CID:$01
- Low sensor Voltage for switch time calculation
Min: 0
Test result value: 461
PASS
TID:$03 CID:$02
Min: 0
Test result value: 512
PASS
TID:$10 CID:$11
Max: 54
PASS
TID:$10 CID:$21
Max: 51
Test result value: 65,535
FAIL
TID:$41 CID:$11
Min: 63,744
Test result value: 65,459
PASS
TID:$41 CID:$12
Max: 512
FAIL
TID:$45 CID:$20
Max: 21,556
Test result value: 13,368
PASS
TID:$4a CID:$30
Test incomplete or dependant test failed
End of report.
What does this mean. LOL are the weird readings related to this? Anyone use torque pro on one of these fossils and get the fuel trims and O2 voltages to work?
Test report:
TID:$01 CID:$11
Min: 512
PASS
TID:$01 CID:$21
Min: 512
PASS
TID:$03 CID:$01
Min: 0
PASS
TID:$03 CID:$02
Min: 0
PASS
TID:$10 CID:$11
Max: 54
PASS
TID:$10 CID:$21
Max: 51
FAIL
TID:$41 CID:$11
Min: 63,744
PASS
TID:$41 CID:$12
Max: 512
FAIL
TID:$45 CID:$20
Max: 21,556
PASS
TID:$4a CID:$30
End of report.
