intermittent high idle
backerm
Tucson, AZ
I've got a 1988 Ford Ranger 4x4, 2.3L. Been having this problem for over a year intermittently. But for the past 3 months it has been happening the same way every time I start it up. It revs to 2000 rpm. When I turn the ignition off and then start it back up after it warms up. Then it idles at 800 and runs good.
Here are some things I've done:
major tune-up
cleaned and tested the EGR
replaced, ECT, IAC, MAP, O2 sensor
checked the TPS
throttle cable
cleaned throttle body, and injectors.
Anyone have any suggestions?
souds like the idle air bypass sticking. it is about 40 bucks.
yep I've tried replacing that months ago. I hate to throw parts at any car. But this is really irratating me.:icon_confused:
Did you reset the IAC when you put the new one on ?
