Effieman
I tried (about 5 times) to shift my 98 into 4X4 the other day. When I turned the switch, the 4X4 light would come on and immediately go off, or blink several times (forgot to count), then go out. The next time I switched it into 4X4 before starting it and it worked, or at least the light stayed on.
Had similar problem years ago where the light would blink 5 or 6 times (forget) then go out. Also had problem with the light staying on indicating it was in 4X4, but it actually wasn't.
Is there anything to check before I just replace the shift motor?
