intercooller worth it?
nolte_martin
dublin, va
is an intercooller worth the hassle under an m90 on a 3.0 or not what air tmeps am i lookin at with or without it
Yes, an intercooler is always worth it. Denser air charge means more power.
I can't avoid detonation with my M90 unless the intake charge is intercooled.
Depending on how much timing you wanna run yes, If you dont wanna do the intercooler, look into the Snow Performance water/methanol kits. (Runs on washer fluid) water keep the temps down and methanol burns good. or something liek that.
will a trans cooler under the sc work running coolant through it not sure if it will be cold enough i know the y did it in some diesel app
