lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
I'm not sure exactly about the 93s but I have seen a couple in junkyards with the same dash and set up like the 92s. If that's the way it's set up, I don't see why it wouldn't be as easy as earlier models, just a few wiring splices. But you'll have to look it over to be sure because at some point the computers started being put in the cowl instead of the passenger foot well. I'm assuming that if it has the older style dash and the computer in the old location, the wiring should be pretty similar.
I believe the motor was the same for 2wd, but the transmission is useless for you. There is no easy way to make the 2wd transmission take a transfer case.
Sent from my kite using a trebuchet
