Is the composite intake larger than the aluminum intake for the 3.0 Liter?
I can build an air box if that will gain me more than the factory plentums.
What is the max pressure the 3.0 intake should run at?
The composite and aluminum intake are very similar in size. The composite does have slightly longer intake runners which may boost torque just a bit, but they are basically the same.
For
