Maritime Storm
Anyone know off hand what is the acceptable variance between measured air temp and what the IAT sensor reads is? Mine reading 10F warmer than measured temp., truck is running lean and has a light stumble under light load when damp as it switches to closed loop. It does this for about 2-3 minutes until it comes up to operating temperature. The ECM is not detecting a misfire or throwing any codes. Not sure where to dig into it. Starts good cold, smooth idle at all times, and runs great warmed up.
