Red beast
- Mar 11, 2013
Ok so i did the odmeter worm gear swap on my ranger its a 95 4x4 manual with 4.0. I was having trouble with getting the speedo to work afterwards. Turns out the circuit board on the back of the instument panel has a little corrosion on it and after messing with it for a while i got it working and powering the guages again. In the process for some stupid fu king reason i pulled the needles off of the tach and speedo. Now they are all out of wack. How do i set them back to their proper locations. I tried to set them with the ignition key on at zero mph but the speedo has a slight delay being the guage starts at 10 mph. Im about 10 mph fast. I have tried numerous times to set it correctly. Is there a special process to reinstall the guage needle for the speedo to get an accurate reading?
I have a second question as well so i will ask it here instead of cluttering the board. When i took the instrument panel out and was having trouble getting the power back to the guages i noticed corrosion on the circiut board on the ip body. (The green film looking part on the back). Well now some of my lights in the dash are working when they feel not when i hit the switch. Its looking like i might have to replace the ip. What is involved with this. Can i just swap a new one in and go what do i do about the mileage on the odometer? Mine is accurate anyway because the worm gear was messed up for some time and wasnt clocking mileage anyway. Can i swap the ip from a newer year like the silver face guages for an 03. Is mine specific because its a 4x4? Sorry if its seems like such stupid ?'s but i am still a newb to the ranger world.
