Chris_North
- Jun 13, 2013
- Automatic
A few weeks ago just down the road from my dad's house my truck out of nowhere shut off and the dash lit up like a christmas tree with the gauges reading way out of range of what my aftermarket gauges were reading. I started it back up, but it was running extremely rough, almost as if multiple cylinders were missing. I pulled into a nearby parking lot, checked some of the obvious things, but couldn't find anything wrong. When I slammed the hood to make my way back to the house the problem cleared up. I couldn't find anything and it ran better than normal until a few days ago when the gauges and indicator lights were lighting up randomly again. I had no choice but to drive it as it was, then the problem cleared up again until today during my commute to work. I wouldn't make such a big deal of it but now every once and a while the trans will randomly downshift for no reason on the highway for a few seconds then shift up again. Then around town after making a turn it seemed to shift up, then want to shift up again, then shift back down ( or something like that; it happened in the span of two seconds so it was hard to tell exactly what was going on).
As far as the cluster goes at least one but frequently all of the following are happening: OP reading too high, coolant reading too high, voltmeter reading too low, gas gauge reading too low, air bag light flickers or lights dimly and gets brighter on acceleration, ABS light comes on, and the "check gage" light comes on (I think this is to do with the other gauges reading out of range of acceptable more than anything else).
I pulled apart the main ECU plug and checked and cleaned it but there was nothing to note. I also pulled apart the molex plug that sits on top of the intake and cleaned as best I could because there were a few pins that had a white film of corrosion on them. I pulled out the instrument cluster and checked all the plugs connected to that and they all look good, and I randomly checked a bunch of plugs in the dash while I had everything apart and they all looked good as well. Pulled a bunch of fuses and relays: nothing unusual. Not sure where to look next.
I have to admit I don't understand exactly the purposes of all the modules and control units scattered around under the dash and listed in the manual. PCM, GEM, and I forget the other one. I also have no idea how the cluster works; if the gauges get their signal directly from the senders or if they all go through a controller first. I am nearly certain I have adequate voltage despite what the cluster indicates as I have an audio system with a large cap with a built in voltmeter that reads between 13.8V and 14.3V depending on how many accessories are on. Same thing with the oil pressure. What really gets me is that I'm fairly certain the OP sender is a simple open/close type (I know stock ones are, this one was changed trying for something else) so I don't get why it would read higher when most of the other gauges read lower. Additionally, the airbag light will illuminate when first turning the key (like the lamp test), indicating to me that the AB module is functioning, but after it goes out it comes back on very faintly and will get brighter as the engine revs. Occasionally a large bump will set everything back to normal for a little bit, but another bump will throw it back or it may just start happening again on its own.
Anyone got any ideas?
Forgot some vital information:
The vehicle in question is a 98 Ranger XLT with the 3.0 and auto trans. It has a butt-ton of electrical accessories added, most recently a Flex-a-Lite for the rad and a trans cooler with integrated e-fan. Everything gets power directly from the battery, including grounds. There are only a few relays for control hooked into the interior fuse panel for key-on power via fuse taps.
