ChrisHelvey
- May 9, 2008
Hi everyone,
So, I pulled my 4.0 OHV from my '94 B4000 4x4 (no problems coming out.)
No problems with the rebuild either.
Now I'm trying to put it back in and I'm ready to pull my hair out.
There must be a trick I don't know about. Anyone who can give some pointers please do. Here's where I'm at:
Engine with the flywheel and clutch are on the engine hoist.
Manual 5spd tranny (Mazda) is still in the truck.
I can get the transmission male and clutch plate female parts to match, but the oil pan inevitably gets stuck on the frame.
I have tried jacking the transmission to different heights, tried getting a backward angle and then lowering the front, but it just won't go back far enough to sit down on the mounting block studs. It's like a half inch shy and won't budge even with a lot of jiggling.
There must be a trick, huh? A special cosmic shoe horn tool? What and how are the best places to attach a hoist?
Should I pull the transmission? (I don't want to because I'm working under a carport on gravel with some plywood and it's getting cold.)
Also, what's with that grey plate between the engine and transmission? It keeps falling out because it goes in from the bottom.
Should something else be jacked up to a height?
Should the engine be "level" as it goes back to mate or does it need to angle back in first?
Anything you know will be helpful. It's my first time installing an engine in a 4x4 Ranger.
Thanks,
Chris
Thanks,
Chris
