installing leveling bushing
scrapper
central IL
IL - USA
Drive
2WD
I got a set of poly leveling bushings with no instructions. I found some but wasnt sure of a couple of things. Bushing small lifted end goes down, and you should leave the coil seat off and bolt the spring right to the bushing. Just double checking, pictures are hard to see. Thanks for any help.
Do a search on the site, Bro. There is a bunch of info here for you. Do a search on installing a leveling kit or adding spacers or bushings for lift. Hope this helps you. I never have used them. I just add taller coil springs to the trucks I have had that have coil spring suspension.
