- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Automatic
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
I suspect no one else has done this, I had an 8.8 that turned out to be junk except for the housing and the axle pads were welded on the housing at 2 different angles-both wrong. I have a stock of parts for the Mustang II I've owned for 30 years so I measured the axle width for the heck of it. A Mustang II rear axle is 1/4" wider than the 91 Ranger rear end that was in my 93. I had a new Yukon limited slip that was for my Mustang, a variety of gears, and assorted hardware. I was able to build a new 8" rear after buying a bearing and seal kit, new wheel bearings, and axle seals. Currie made me a pair of 5 lug axles(about $500) and the 10" Ranger backing plates bolted right up to the Mustang II housing like they were made for it. I was amazed and pleased that I didn't have to use the 9" Mustang II brakes. I got the universal shock brackets and 65-66 Mustang spring pads from Currie, too, and welded them on. An 8" is the same design as a 9" so it's easier to work on(IMO) than an 8.8 and I can change the gear ratio quick and easy if I want to. I drag raced my 13 second Mustang for over 20 years and never broke the 8", I'm confident I won't break this one going to the transfer station, the hardware store, and Home Depot.
