iamlew
- Apr 7, 2009
- Automatic
So I FINALLY got my transmission to go in, and I went to turn the motor by hand via the bolt in the front (cam shaft bolt?) and it didn't budge. So I took out the breaker bar and got it to turn but the belts didn't budge. I tried the other direction (loose) and the bolt started to come out. The flywheel also doesn't turn (wanted to bolt the torque converter on). It turned by hand yesterday when I needed to move the flywheel to line the bolt holes up.
The only thing we can think of is it is bound, or we bent something. Which is possible because we had the transmission lined up and it wasn't moving, so we let down the jack holding the engine up and everything slid into place. Didn't hear any noises however, and it went really smoothe. So we bolted it in, and went to try and do the torque converter and realized nothing happened.
The transmission has 2 bolts out still one on the left on on the right, but I thought that wouldn't make my motor not turn so I haven't bothered putting them in yet. And the transmission is flush with the motor form what I can tell.
Could this be from the torque converter not being seated on the transmission. it wasn't "clicking" when we spun it around on the flywheel before the trans made it all the way in, and we took it down TWICE to try and seat it better with no luck. Any ideas?
Oh yeah, it's an 87 automatic. the trans is an a4ld from a 89 b2.
