installed new 4.0 clutch flywheel and starter truck died with clutch pedal pushed in
stamina
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
finished swapping everything for the manual went to burp o the new radiator and start the truck, clutch pedal to the floor to start and in neutral, when i let the pedal out, the truck runs normal no problems there. when i push it back in or as soon as i’m starting the vehicle and i don’t release it, the truck dies. does this have something to do with the 4.0 flywheel and pressure plate? i still need to finish bleeding the master and i will do that on the bench but this doesn’t make any sense i feel. everything was torqued to spec and done to a T. i’m confused
