Installed 2" susp.lift still leaning to the left
wvabeer
Evans , West Virginia
I installed the Skyjacker suspension spring lift front and rear and this thing still leans to the left 1" in the front and 1/2" in the rear. Should I shim up the left front to make it even?
have you measured your brackets to make sure they are the same hights. and also i've some lifts have different rated springs on each side because of the weight so you may check that too. but i don't really i'm not and engineer, yet!
how long has the lift been on? maybe the springs havent broke in yet
I put them on last night drove it around today and it still is leaning I wonder how thick of spacers I will need to lift the left side 1" ?
