"It will run like shit, especially on the stock MAP/SD computer. LOL, shoving gas down your engine's throat is certainly not going to help things. The PCM doesn't know that the flow rating is higher for the injectors and tries to make it's adjustments based on 14lbs.
Only way I got it to somewhat work is with a MAF conversion and using an IST MAF air adjuster for fooling the PCM. End result was an engine that ran really rich at idle, but it really did help at WOT (I got pretty lean w/ 14lbs), but I also have a high lift cam and other mods done. I am running stock injectors now (for a year maybe?), can't get what I want out of the 2.9L, working on 5.0L swap. Just been driving it and keep up on maintance...
Best bet would be to retro fit some sort of S/C or turbo setup. Possible, but no kits avail.
Pete"
I agree, for the 19lb'ers to run at the correct a/f mixture, your engine
would need to REQUIRE tthe extra fuel--- and your speed-density injection
system is unable to compensate.
I changed to 19 lbs, but the heads are ported, tubular headers, cam,
flat-back stainless valves, MAF conversion with IST Adjuster.
It flows a greater amount of air, so it requires more fuel than the 14lb'ers
can provide............and I still get 24mpg.
Jeff
