Injectors advice
firetaz6235
RBV's on Boost
I'm looking for advice on what injectors to go with my 4.0 OHV when I put my stage 3 Tom Marano heads on. As I said, I have the stage 3 heads, 66mm throttlebody, spacer behind the throttle, pacesetter headers, K&N filtor, E3 spark plugs, accel coil pak, Taylor wires. Later I'll put a 410 cam in it. What ohms of injectors would be a good match? I found a guy that will dyno and program my computer after I get it done. Thanks for any advice
Get a 99/00 80mm Lightning MAF and some 24# Ford injectors and you'll be good to go - the injector drivers in the PCM require factory style hi-impedance injectors.
Bird
Hey thanks for the advice. I forgot to mention that I put a after market MAF. Would that sufficient?
As long as your tuner knows how to datalog and adjust the MAF transfer function, it'll all work fine.
Sounds like you've got a nice package there with room to grow.
Bird
