whitebroncoii87
Hi, according to this diagram http://www.therangerstation.com/tec...es/Diagrams_ElectronciEngControls2_9_3of3.JPG
injectors 1, 2, 4 are wired together
injectors 3, 5, 6 are wired together
I don't know if their injector numbers correspond to cylinder numbers but I did a continuity test on my injector harness and I have the following (I am labeling my injector numbers to match cylinder numbers):
injectors 1, 2, 3 are wired together
injectors 4, 5, 6 are wired together
I remember someone mentioned injectors are fired 3 times on one bank and 3 the other bank, in that case shouldn't injectors 1, 3, 5 be wired together and 2, 4, 6 be wired together. Neither the diagram or my harness has this configuration. How is that possible? ... Thank you!
