2.3L ('83-'97) Injector sizes for dual plugs engines
East Texas
TX - USA
2.3 (4 Cylinder)
Anyone know the exact stock injector size for the dual plug head engines?
How much bigger will the engine take with out a tune and still run right?
What is the goal behind your question? Are you having an issue you are trying to fix or are you looking to get more power out of the engine?
That will help tailor an answer better in replies and suggestions.
Just replacing with newer multi hole injectors.
I thought the earlier rangers had 19lb but lowest I find for ford brand is 24lb
Power isn't my goal but would be nice but don't want crappy economy/hard start/rough idle
Power isn't my goal but would be nice but don't want scrappy economy/hard start/rough idle
Cool. I don't have the answer but the next person that comes along might. So, now they know the context and situation.
I was curious about this a few years ago when I needed injectors and had different ones laying around.
'92-'94 has grey CM-4670 which everyone seems to agree are 14lb.
'95-'97 has red CM-4779 which gave me more trouble. These guys claim they're 19lb. This ebay listing for a compatible part claims 88ml/30s, which should be 17lb.
I know it's not 2.3, but the different injectors on a 4.0 from 92-94 (Black vs. Red/Orange) worked exactly the same for me.
Quick search says Standard black FJ694 ('90-'92 4.0) and red FJ693 ('93-'96 4.0) are both 18lbs. Both look like 4-hole. Not sure what the difference is, then.
When I temporarily put red '95 injectors in my '94 (2.3L) it ran well-enough to get me around, but it was hard to start after it got warmed up. Stock on stock is going to work better.
I got newer 4 hole injectors for 99 5.0 explorer. Supposed to be 19lbs.
Put everything back to together and something caught on fire near injector 1/fpr. Put it out have to take upper intake back off and look at it next day off.
I'm not sure if they're supposed to be an upgrade in some other way, but I don't think you need to go to the skinny plastic injectors to get 4 holes.
Me too! Same
