injector lb chart
4b316
Been a lot of questions and info on here.here is a chart that we have been using http://users.erols.com/srweiss/tableifc.htm#BOSCH_FORD just get your part number and cross it.Or http://oldfuelinjection.com/?p=38 This chart works pretty well but they don't have all the info.If you take the part number from the 95 ranger red top injector,you find that they are 19lb injectors.A vendor got caught on ebay selling these as 30 lbers and had to pay back money.You need to check part numbers to be certain.
My gosh~!
I guess if you use it on a daily basis it probably makes sense...but I thought it would tell me what orange tips meant...:)
It will,just take your part number and check it against the list.
Yeah, I will do that maybe next week when I'm down there...one of the problems with having to store a vehicle off site...
I know the tips on the 2.5 injectors were orange so I thought that was all I needed to know...
Usually they are,gray 14 lbs,yellow/orange 19,lt blue 20,red 30,dk blue 36 and green,42.The only thing I have found different is that Ford red injectors in the early rangers,2.3,4.0 and a few other flowed 19 lbs and were a maroon/red color.To be positive in what you have,run the part number.still searching on pintle info
Injector Lb/Hr Max V8 HP HP supported by 1 injector Ford Color*
14 Lb/Hr 228 28.56 Gray
19 Lb/Hr 310 38.76 Orange
24 Lb/Hr 391 48.96 Lt Blue
30 Lb/Hr 490 61.19 Red
36 Lb/Hr 587 73.44 Dk Blue
42 Lb/Hr 685 85.68 Lt Green
60 Lb/Hr 800 100
