Injector help!
Rightroofing
Ok first I need to inform y'all of how it started. I was in a minor accident and just got a dent in the bumper. Truck stalled and didn't turn back on, no fuel. I got it towed home where I searched for the reason the fuel pump was not receiving any fuel, not the cut off switch under the dash. I Gave up and just ran a manual power from battery with a toggle switch. The fuel pump kicked on perfectly but she till didn't turn on. I'm gelling pressure to the fuel rail but the injectors are not firing. Please help me get her running.
1994 2.3l single cab
New coils, wires, plugs, ICM
did the bags go off?...does a 94 even have bags?
do you have spark?
does it crank? or click or anything?
and you have fuel at the check valve? .....the pump is hot wired to a switch....
sounds like you did more then just a dent.....i would pull one injector at a time to see if its has fuel or not....
Ok yea that sounds good didn't think about that I'll do that and get back to y'all
what motor is it.. 4x4?where on the truck was the hit?
lol....no need for 2 posts about the same thing buddy......check your other
take a few feet of rubber hose & use it like a stethescope....get someone to crank the truck....can you hear the injectors ticking when the engine is being cranked? FYI-----The electical connector to my injectors was corroded slightly which caused them not to click/or squirt fuel.
Ok I put the hose to them and no pulse frOm any. Idk what else to look at all 3 relays are good .
