- Aug 3, 2011
The stainless steel fuel pressure line that is in the engine compartment going to the enjection manifold is leaking on me. I changed the head gaskets and during reasembly I went to tighten down this fighting and was holding onto the 90 while tightening it, and i ended up cracking it. I've tried JB welding it it but that doesnt hold up to gas, and then i put seal all on put that doesnt seem to be holding up to the heat.
So now I cut the fitting off, installed a 90 and a barbed fitting, a high pressure fuel line clamp, and that is leaking. So now i goobered up a bunch of seal all around everything...
Im wondering if anyone else has had an issue with this or if any one has a suggestion on how to get this fixed. I've searched and can't find the fuel line and i was fighting to get the quick disconnect disconnected without any success...
Attached is a photo of the line I am talking about.
http://postimage.org/
Also, what is that metal thing that is crimped onto the line?
