Info
lisky13
Woodstock, ont
Hello folks.
First time posting here. Can anyone tell me how far I can lift the front of my 4x4 2010 ranger before the CV shafts are an issue? I have the level keys in now but it still needs to lift up more. Or point me in the right direction.
Thanks.
As soon as the geometry has changed it starts to stress components. I wouldn't go past 2 inches with keys. The upper control arm becomes an issue and the suspension drop travels goes away, basically making your suspension worthless. A key lift is good for leveling. If you want more, you need to do an actual lift. I have keys in mine and lift shackles in the rear, but if I were to go any higher, I will be doing a 3-inch body and the 4-inch suspension lift. There are plenty of threads on TRS that explain the different lifts.
