info on v8 swap
crazyranger
I have a 2000xlt 4x4 3.0 ranger. Im considering putting in a 5.0 from a 1997-2001 explorer or mountaineer. My setup after swap 5.0 swap will be, 3in body lift 4.10s and 33s < cosmetic. On the motor k&n cold air intake, throttle body spacer, some kind of preformence chip, and a flowmaster. Now the main reason im doing the swap is that i have a 18ft bass boat 150hp on the back im around 3000 lbs. I want the power to trailer, But if the 5.0 and this setup is going to kill my mpg Ill just conider a 4.0 swap.My mpg now with 3.73 31s is 15 city 20 highway. What mpg would you except to get with the 5.0 setup? Is it worth it?
Your milage will be better with the 302 then it will with that gas hog 4.0l V6. Your milage probably will be almost the same as it is with the 3.0l V6.
