Dwayne Long
How do know or how do you know if the inertia switch is bad
Unplug the inertia switch and check continuity between the pins, if it's open push the reset. Might be worth checking the fuel pump relay,too.
You can just run a jumper wire between the two terminals of the plug and see if the pump runsThanks but tried everything so I took it off the firewall unplugged it and when the button is reset you can shake it and sounds like its full of small gravel
