Indicator light won't go off. HELP!
1986B24x4
I need some help. I have a 1986 B2 with a BW1350 manual t case. In the top of the t case there is an indicator sensor that tells you what gear you are in (4hi, 4lo, ect ). No matter what I am in, even 2hi, my dash shows 4lo. I can shift into 4hi and then back into 2hi and it will go off but eventually come back on. I can unplug the connector on the sensor and the lights go out. 4wd seems to work fine, just the lights are acting funny. Any ideas?
I fixed it. Nvr mind y'all. Also found an aftermarket replacement after 12 hrs of searching. Helps when you pull the part and get the original part number off of it. Thanks for nothin.
