In tank fuel pump
jmcleek
Does anyone know how much pressure the in tank pump puts out?
John
It is regulated at the rail at 39 or 43 psi, its capable of slightly more, why are you asking?
If an 88 has two pumps, the in tank pump is a lift or transfer pump, delivering flow at a low pressure. I'd guess 3--5 psi. Then you have an accumulator can, the high pressure pump on the frame rail and a filter.
The 87 I am working on has two pumps the one in the tank is the low pressure one ,the one on the rail is the high pressure pump . Going with a carb. so don"t need even a 1/4 that pressure.
thanks Earl43p Will that be enough to feed a carb.?
If you are going carborated, the 3-5 psi wont work, you need 7 psi. You can buy a regulator that will allow you to knock down the high pressure pump to 7. Or you can put a tube in place of the low pressure pump, so its down at the bottom, and put a 7psi pump in line (any off the shelf at your local parts store) or the mechanical pump for a carb motor, but that also requires the aux shaft to be replaced so its not quite worth the work.
Thanks Mikel89us ,may have a 3rd option , what is the max pressure for a carb? mechanical pump would require moveing the alternator and as stated other changes.
You will need 7 psi, any carb you can run on this motor will likely be a 7psi carb, import cars run anywhere from 3 to 9 psi, but why would you want to bastardize it like that? haha! My personal suggestion is go to the parts store and get a Mr Gasket 7 psi pump off the shelf. They are a little noisy but they work well, I used one on my racecar (2.3 mustang) for years and never had issues, except one leaked after a hard wreck.
