Jeremy-b
I’m have a 2001 ranger. Can anybody send me in the right direction to find a sway bar for my truck? It’s a discontinued item.
Thank you for responding but I haven’t had a chance yet to check local junkyards the mechanic that looked at it said it should be replaced I have the links and bushings he suggested the whole bar be replaced I haven’t looked at it yet I’m gonna check tomorrowFront or rear? Rears just need to have clearance around everything, bought one for a car once from J.C. Whitney many years ago. Worked fine. Old Datsun, but a sway bar is a sway bar.
Front is going to be a bit more specific. Have you searched the nearest junkyard? They really don't wear out, although might need new bushings for the end links. Don't see any advantage in buying a new one, if something else can be made to work.
And by the way it’s for the rearThank you for responding but I haven’t had a chance yet to check local junkyards the mechanic that looked at it said it should be replaced I have the links and bushings he suggested the whole bar be replaced I haven’t looked at it yet I’m gonna check tomorrow
I don't think that they are standard equipment, his truck may not have came with one. Or as you noted, maybe it got damaged.Uh.......
I think it is appropriate to ask WHY it should be replaced. Unless badly deformed (wreck?), or you were running the Baha 1000...... they don't wear out.
Fails to pass the smell test, to me.
I haven’t looked at it yet. Mechanic said it was no good.I don't think that they are standard equipment, his truck may not have came with one. Or as you noted, maybe it got damaged.
AJ
Um..... I think I would be a little suspicious of "it's no good." Like I said.... they don't wear out. WHY is it "no good"? Does he have a boat payment due?
Lol. No, boat payment due. I looked at it. It is broke. Right where it goes in the rubber bushen.Um..... I think I would be a little suspicious of "it's no good." Like I said.... they don't wear out. WHY is it "no good"? Does he have a boat payment due?
It’s snapped in the bushing.Aside from extreme rust I don't see why the rear sway bar itself would ever go bad.
Of course bushings go bad but but still... no need to replace the sway bar.
In fact the whole thing was an option. A great many Ranger's left the factory without one.
I just swapped one onto my '85 that didn't have one from the factory. I pulled it out of a VERY crusty '93 and the sway bar was perfect yet. Bushings were too, all I did was clean it and paint it.
