Hey yall!
So long story short, helping a family friend fix his Daily driver 1987 B2. 7.5" rear end ring and pinion job turned into much more.
So two part post..
Rear differential bearing cap is broken. After much research they are machined to the specific axle. Can I just throw another cap from a 7.5" on and hope for the best? I assume not, it'll likely not work and cause issues... right?
Part two:
8.8 swap.. I live a mile from the pick a part, they have a ton of rangers. What years would be the best to pick from for the rear? I know i am going to have to weld new perches on. What about shock mounts? Do I have to do anything to the brake system if I put disc brakes on the rear and keep the B2 front axle?
It has the U joint style drive shaft, do I swap the rear flange on the DS from the one on the ranger? Or drill and tap the flange on the 8.8?
To sum it up, if I cant just throw a bearing cap on, I'd love to find a 8.8" rear, drum brakes, with limited slip. What ranger should I look for?
Thanks in advanced,
Sincerely - The nice guy who does too much!
So two part post..
Part two:
Thanks in advanced,
